Salta al contenuto principale
Repair guides for the Magic Trackpad. Released in 2010.
25 Domande Visualizza tutte
battery acid damaged batt-compartment - how to restore?
Hi together,
I own a Apple Magic Trackpad, where the batteries ran out and damaged the battery compartment.
I removed the batteries and cleaned the battery compartment. Now, the batteries have a little bit axial play (2mm?), so I have to put some metal spacer in between. And the Trackpad is only working sporadically, I suggest a bad contact problem.
When I look into the battery compartment, I only see a elastic radial spacer and a (always corroding) center contact.
Does someone has any suggestion, how to resurrect the trackpad? Is there any part missing in the battery compartment? A spring maybe?
Pic of contact
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Try using a Q-tip and some isopropyl alcohol (no contact cleaner) and or a toothbrush to scrub it away.
Punteggio 0
Aggiungi la tua risposta
kaufschorsch sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 209
