Salta al contenuto principale
Quinta generazione dell'iPhone. La riparazione di questo dispositivo è semplice e richiede cacciaviti, strumenti di apertura e pazienza. Nero o bianco, GSM/CDMA / 16, 32, o 64 GB.
2193 Domande Visualizza tutte
New replacement battery sometimes cannot charge
I replaced a battery to my iphone 4S and for one month it was able to charge daily. I got the battery replaced thinking that maybe the battery was not good. The 2nd battery was initially with 76% charge. I tried to charge the phone but it never charge even after 1 hour. I am using any original Apple charger and 30pin cable. Also tried with another charge and cable but also same situation. Hard reset(POWER+HOME) also did not help. Also did a firmware upgrade from 9.0.2 to 9.1, also doesn't help. There was 2 occasions where I found that the battery have to be totally discharge then it was able only to charge to about 26% and it stop charging.
Anyone able to advise?
Below is the battery check using ibackupbot:
CycleCount: 0
DesignCapacity: 1420
FullChargeCapacity: 1200
Status: Success
BatteryCurrentCapacity: 25
BatteryIsCharging: false
ExternalChargeCapable: false
ExternalConnected: true
FullyCharged: false
GasGaugeCapability: true
HasBattery: true
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Seems like a new battery if the cycle count is at"0" where did you order this battery from and what problems did your original battery have ?
Punteggio 0
Bought the battery from online store. Original battery of 4 years iphone 4s initially cannot hold charge for more than 3 hours after that it cannot charge, so I replaced to a new battery.
Punteggio 0
2 Commenti:
It may be a faulty battery, i would turn it off then resest the battery conector then ser if thst heps. If not send it back.
da
The battery is okay. I replaced the iphone 4S Charging Port(which include the flexible cable), it solved the battery charging problem.
da
Aggiungi la tua risposta
John sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 148
