Salta al contenuto principale
Truck turns over and shuts right back off
Truck turns over and shuts right back off. I have changed fuel injectors plugs and wires oil and oil filter changing the mass flow air sensor tommorow really could use some insight
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
You likely have a bad sensor or one that the plug is loose on. It's probably the MAF sensor or plug from your description .
Punteggio 0
Next thing to check is to see if it is getting fuel when you have this problem. Maybe a weak fuel pump.
Punteggio 0
Aggiungi la tua risposta
Logan collins sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 92
