Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Front and Rear Camera does not work after screen replacement
Hello,
Recently I have replaced iPhone 6 screen. The problem I have now is that Rear and the Back camera does not work, flash-light as well. It looks like everything else apart these works fine. Then I turn on them, they are just completely black. I tried those cameras on other iPhone 6 and they did work. I tried to erase the content of iPhone but it did not help. Right now I am giving a try on DFU mode and will update what is happening. Somehow I believe that I occidentally shortened with static charge. Anyone else any thoughts on this?
Thank you for your help.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Looks I am lucky as DFU mode sorted everything out. However, I assume that it was a step from disaster.
Punteggio 0
1 Commento:
Glad to hear that fixed it for you! When we saw one from another shop it did not.
da
Sounds like board level issue. I'd have to look up iPhone 6 but on iPhone 5 it was the compass ic that was damage somehow & it controls both camera functions.
Punteggio 0
Aggiungi la tua risposta
Lukas1 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 96
