3rd party Qi charging options for Nexus 6P
Are there opportunities to add Qi charging using third-party coil add-ons? My great disappointment is this not being included or at least an option.
Questa è una buona domanda?
Perhaps a solution like iQi (currently available for Apple devices) will be released.
The only drawbacks of such a solution are:
1)that the charging module is attached over the phone so you should use a thin case to hide it;
2)using the phone's USB port may be problematic due to charging module cable attached to it.
I had been keeping that as a fall-back. Thanks for the insights.
I use a "stick on" module, and it works pretty well.
Sure, it only charges at 1W, on a good day, but I can trade the fast-charge capability for the convenience of wireless; I've had this installed since the first week of ownership.
You can sync almost everything, easily, using wireless (either Bluetooth or WiFi), so there's not a lot of reasons to need to connect it to a computer, physically, IMHO.
Obviously (I think), this involves a case, something to cover the Qi charging coil. There are numerous USB-C stick-on modules out there, of various qualities, definitely need to read reviews, and choose one with a flush-mount cable (to keep it protected, by the case edge).
Not internally, the case is metal so Qi charging won't work through it.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 3,308
1 Commento
Thanks, that's what I feared. Do you know if the back is removable, maybe there will be enough interest someone will fabricate a RF porous replacement and find accessible attachment points for charging... Not likely I guess. :-(
da Perfectly Frank
