Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
I got error 47 iTunes
Hi,
After a new restore and screen remplacement, my iPhone is working perfectly but I must activate it. I have tried to activate it but with no success so I've tried to restore it in iOS 9.0.2, When I come to the (Restoration of the internal program) my iPhone blocks in the apple logo with the bar in 3/4 of the percentage... After 3-4 minutes iTunes says Error 47 ! So I hope you help me with this issue.
Mise à jour (21/10/2015)
Here is the exact problem as me :
I also have this issue, the phone seemed fine but it was stuck searching for network, I erased all content and settings but I then couldn't activate the phone (still searching for network), so I thought I'd try a restore and try activating through iTunes, It is now stuck in restore mode and repeatedly giving me error 47, whatever the problem is wasn't causing too much grief before I tried to restore it so messed up now, fails everytime installing the firmware and I'm clueless as to what the problem is
June 6 by Itchy ///////////////FOUND IN : How to fix Error 47
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
4 Risposte
Soluzione Prescelta
Didn't somebody ask about this recently...
Error 47
it you have Error 47 it a hardware problem with baseband Check your imei or Baseband
You can also try putting it into dfu and doing a restore from a backup
Punteggio 1
14 Commenti:
It's not a Logic Board Problem because it was running normally before I've tried to restore it. few seconds ago !
da
Didn't say it was a hardware problem
da
Er logic board probelm. Whatever. Check your baseband. Or don't, either way
da
How to check the baseband ?
da
Try this stuff
da
Mostra altri 9 commenti
In the iTunes Update Log, I've ramrod error 1004 // and something with Baseband
Punteggio 0
This happens after I've changed the iSight cam, if I remove it can this error fix ! and also, when I've tried iReb to kick out the iPhone from recovery mode it's showing me the apple logo for 20secs after it's shutdown immediately ! (When I've opened the iPhone for the first time, I've found that the battery was removed alone ! Can it be the battery ?)
Punteggio 0
software no solve error 47 iphone 5
Punteggio 0
1 Commento:
iphone 5 error 47 software not solve
da
Aggiungi la tua risposta
ilyesbouira sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 4,484
