Salta al contenuto principale
Il Palm Centro era lo smartphone più piccolo offerto da Palm al momento della sua introduzione e include una fotocamera digitale da 1,3 megapixel.
How do I fix Flashing?
My Palm's screen and keyboard are flashing. I've tried removing the battery and powering down but it just keeps flashing. Can this be fixed?
Questa è una buona domanda?
Punteggio 1
1 Commento
I did a hard reset on Palm Centro five times; data still there
da Condividi
Aggiungi un commento
1 Risposta
Soluzione prescelta
What you have done is the soft reset. Palm has 3 more types of resets.
- System or Warm reset
- Hard reset (possible removal of data from device)
- Factory reset (guaranteed removal of data from device)
Since you may loose data, I would suggest you connect the Centro to your computer & use Palm hotsync to backup your data.
The directions to do each of these resets are found on the Palm website here
http://kb.palm.com/wps/portal/kb/common/...
Try these steps & post the result (whether it worked or not) back here.
Punteggio 0
Aggiungi la tua risposta
Sarah sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 27
Tutti i Tempi: 2,539
