Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2506 Domande Visualizza tutte
What kind of damage is on the LCD, and is it repairable?
I have a problem with my iPhone 5. I opened it up to fix the lightning port, and when I turned it back on, it seems to have pressure marks or some other sort of damage. I googled and am not sure what kind of damage it is or how I can fix it. I tried massaging it already, is it repairable? I don't remember being hard on that area.
Questa è una buona domanda?
Punteggio 0
1 Commento
It was dust, because after I used it, the 'damage went close to the edge.
I have no idea how it got in there, but for everyone else who's looking at that, try banging it on your hand or something.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Yeah, damage to the lcd. Just about any amount of pressure on the back of the lcd, can hurt it. You could just ignore it, or you could swap out the part
iPhone 5 LCD and Digitizer
Immagine iPhone 5 LCD and Digitizer
Prodotto
$39.99
Punteggio 1
1 Commento:
What kind of damage is it? Is it pressure damage? Its non repairable as in repair, not replacement?
da
hi Alex,
it is the LCD display assembly broken, need replace . before my friend buy from partsifixit.
Punteggio 0
Aggiungi la tua risposta
Alex sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 388
