Stuck at step 40 in Display Assembly Replacement
Hi all,
My iPhone 4s has a shattered screen so I ordered replacement part from Amazon. It arrived and I started following the steps here for replacing the LCD assembly. I got all the way down to installing the new LCD assembly when I got stuck.
Sostituzione schermo iPhone 4S
At step #40 / 41, the instructions tell me to make sure the new display's cables are pulled through far enough to be reconnected. The step says, "Carefully straighten the digitizer and LCD data cables, and feed them through the slot cut in the outer case.".
I am doing that, but it's not going through as far as the "correct" picture shows. It appears one of the cables is glued down to the back surface of the face plate, so it won't be as long as I need it.
I'm not sure how to proceed without ripping the cable. I feel like I'm trying to do something I shouldn't. Is this normal? Any suggestions? Thanks!
Questa è una buona domanda?
