Salta al contenuto principale
Una console di gioco per la televisione prodotta da Sony Computer Entertainment, conosciuta anche come PS4. Annunciata il 20 febbraio 2013 e lanciata sul mercato il 15 novembre 2013.
ps4 update bootloop problem.
I bought the Playstation off cl knowing it had a problem. Keeps failing updates. Ive replaced the hdd with ssd, and installed software with several usb drives. i also tried the software its on 2.04 and every thing between current 3.00. Before I have it repaired was hoping there is a fix. I was thinking maybe pulling the cmos battery. the error code is su-30631-3. model cuh-1001a.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
6 Risposte
You have to upload the full system software not just the update
https://www.playstation.com/en-us/suppor... (scroll to the very bottom of the page)
apologies if you've already done this - but i made that mistake once
Punteggio 0
1 Commento:
I used the full 800mb software file of several versions.
da
I have the same Problems. Anyone a solution?
Punteggio 0
I have similar problem since my son tried to install the update a few weeks ago. we've tried installing the full version oo and although it appered top work, a couple of days later the PS4 just keeps rebooting and saying you need to install the system software.
Will try contacting Sony support, but if anyone has any answers as to why an otherwise perfectly working machine should just fail like this following update, I'd be grateful - so will my son!
TIA
Punteggio 0
Same problem and no solution.
Meme probleme et pas de solution de sony
Punteggio 0
Has anyone found a solution? Same problem here:(
Punteggio 0
1 Commento:
Have you solved the problem? Thanks
da
In reading online this particular error is caused by the NOR Flash being corrupted. The onle fix listed i have read is to unsolder the flash and decode the dumpfiles.
Punteggio 0
Aggiungi la tua risposta
Kyle Simmons sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 3,700
