Salta al contenuto principale
1994 toyota pickup dies when put into gear
Have a 94 toyota pickup and when you put it into gear and take off it dies like you turn the key off not sure if it's a ground wire problem or what any ideas are helpful
Questa è una buona domanda?
Punteggio 0
1 Commento:
Do you have the same issue when it is not in gear? It only happens when you drive?
da
Aggiungi un commento
2 Risposte
It's not likely a ground problem. Probably a sensor. The only time I have had trouble with my truck not running it has been a sensor. Check all connections, unplug and plug back in. You'll probably fix your problem.
Punteggio 0
You should also check to see it it's getting fuel when you have this problem. Could be a weak fuel pump.
Punteggio 0
Aggiungi la tua risposta
Jeremy Hedges sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 284
