iPod classic battery replacement
Where in south Jersey can I get my iPod repaired. I believe it is just in need of a new battery since I get absolutely nothing when I charge.
Questa è una buona domanda?
I dunno if you're feeling savvy. You could try this
Sostituzione batteria iPod Classic
Using this
If this sounds like it's too much for you, it probably is. There's nothing wrong with that. A simple google search, could help you get in the right direction, of finding local repair shops in your area. You may have to try a few times, before you find the right one for you
Try www.Iresq.com
(That's "I rescue" being cute)
Phil
BTW if you try it yourself using one of the Youtube videos, you need to be aware that the ipd Classic 6 is a thick battery and the Classic 7 is thin coz it's a thinner case
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 223
1 Commento
It's a bear to open. Once it is open the rest is easy. So, if you are going to repair it by using the guides, do not get discouraged. Use a good putty knife and have at it.
da oldturkey03
