Salta al contenuto principale
Una console di gioco per la televisione prodotta da Sony Computer Entertainment, conosciuta anche come PS4. Annunciata il 20 febbraio 2013 e lanciata sul mercato il 15 novembre 2013.
1697 Domande Visualizza tutte
Fan Making This Noise After Coming Back from Sony Repair?
Anyone know what would be causing the fan to do this?
https://youtu.be/VeF9XoOjnJo
I sent it into Sony Warranty repair for a HD issue and it came back doing this. I'd prefer not to send it back to them for a month in hopes of maybe getting it back in good shape (Fallout is coming out in a month!). Is there any easier fix than taking the whole thing apart to replace the fan?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
That noise is caused by the console getting hot. I've never seen the fan itself cause the problem. If you are installing a game or doing something that it very graphically intense then sometimes PS4's will turn the fan up like this to cool it down. There are a few things that I've seen cause this problem:
-No thermal pads on memory chips
-Loose heat sink screws
-no or not enough thermal paste
I would think that Sony would not make any of those mistakes when putting a console back together, but I know that they often don't even send your console back to you and instead give you a refurbished unit.
I hope this helps.
Punteggio 2
Aggiungi la tua risposta
whitty26 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 112
