Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3530 Domande Visualizza tutte
Domanda Chiusa
Is that possible to replace basebad chip
Hi,
I got an Iphone 5s in 5$ , it was working perfectly as IPOD, but during updating IOS its stuck in Apple Logo , i show the phone to a local repair shop they said Basband chip is damaged and you need to replace the logic board.
But , my questions is i see many places like Aliexpress, Ebay .e.t.c have Baseband chips available , is that possible to replace the baseband chip only , will device will start and active after replacing ?
Thanks
Questa è una buona domanda?
Punteggio 0
2 Commenti
Ehh... I dunno. I mean, yes it is possible. I believe. Jessa Jones will know for sure
da
Who is Jessa Jones?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Daiyan, the baseband chip is a BGA that will require a reball. So you will need to have a reflow machine as well as the right stencil etc. to do that. Even if you have all that, the IC needs to be pre-programmed to function with your phone, since there are multiple IC that are dependent on each other. Yes it can be replaced, no it is not going to work with your phone.
Punteggio 2
2 Commenti:
Hi, Thanks for giving details , the final option is to replace the Logic board.
Btw any idea or tips to make it out from Apple logo problem , its turning on and Showing ITunes , i used reiboot to make out from Recovery Mode but still its up and turning off after few seconds.
da
Well, again not sure, but you can send it out to a repair shop, that works or specializes in micro soldering
da
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 146
