Salta al contenuto principale
The Xiaomi Mi 3 is a high-end, premium Android smartphone that is produced by Xiaomi.
22 Domande Visualizza tutte
Domanda Chiusa
Problem after replacing touch
I replacement my lcd Xiomi mi3. With the complete replacement lcd touch and frame,
following the guide.
Unfortunately, with the new part.It works only the high part of the touch.
I damaged something? the touch is faulty? Help thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Do you check the part before replacing? May be the LCD touch is in bad quality. Or you need to replace it again. If it still cannot work, or just like what you said you damaged something, you can take it to the repair shop and ask the maintenance staff for help.
Punteggio 1
1 Commento:
ok thanks, replace LCD.I will update on the resolution.
da
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 145
