Salta al contenuto principale
Repair guides and support for electric and gas-powered high-pressure sprayers sometimes referred to as power washers.
38 Domande Visualizza tutte
Simoniz pressure washer leaking from gold spring thingy
Hi there I have a pressure washer that's leaking water out of a gold spring thingy I'm not sure what it is or how to fix it any help would be appreciated
Update (10/08/2015)
Gold spring thingy
Questa è una buona domanda?
Punteggio 2
2 Commenti
Can you elaborate? Could you provide us with a manufacturer, model number, or year? What is the "gold springy thingy?"
da
Aggiungi un commento
3 Risposte
Risposta Più Utile
Hi Mike - That gold springy thing is the adjustment spring for the unloader valve. It makes it so water flows even when the trigger isn't in use. This keeps the pump from running dry. Inside the spring is the adjusting bolt. You should be able to tighten and loosen the bolt to adjust the unloader pressure. I would assume these things were done in the factory before shipping to you but possibly you may need to loosen off the nut to stop the leak. Another possibility is an o-ring/nut has cracked where the water is leaking through. All in all this is definitely something that would be covered under warranty.
Sources for further reading:
http://www.ppe-pressure-washer-parts.com...
http://pressurewashr.com/pressure-washer...
http://www.epowerwash.com/wp/archives/63...
Punteggio 2
Sources for further reading:http://pressurewashr.com/pressure-washer...
Punteggio 2
Hi, Mike. That's a Great question . This keeps the pump from running dry.It makes it so water flows even when the trigger isn't in use. Even I appreciate with @jamar . Aslo Tnq @jamar for providing your valuable opinion . Thanks to all. Washer Daddy
Punteggio 2
Aggiungi la tua risposta
mike sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 26
Ultimi 30 Giorni: 62
Tutti i Tempi: 3,743
