Salta al contenuto principale
Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
376 Domande Visualizza tutte
Domanda Chiusa
Yellow-ish screen with lines after reassembling the logic board
My screen looks yellow-ish in color, and is not bright enough, and I also see white vertical lines on it. This happened when I reassembled the logic board and reconnected the monitor data cable.
I'm quite sure I plugged the data cable very deeply till the end...
When removing the logic board, I had accidentally strapped off the gray tissue piece off the cable, and also a little bit of the black electric tape has fell down from near the screw. Could this be the problem?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Nver mind, already solved by changing the display.
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 64
