Salta al contenuto principale
Repair and support for the 2015 version of the Google-produced laptop line, the Chromebook Pixel. This newer version improves the processing power, battery life, and adds new features to the 2013 model.
Liquid damage to keyboard, display backlight went out.
Hey I have a Chromebook Pixel (2013) that was working fine until soda spilled on my keyboard near the 40 pin connector on the motherboard. I took the laptop apart and cleaned off the soda and corrosion. There was corrosion on a resistor(?) named r005 and after I cleaned it I noticed it looks fried. The display works when connected to an external monitor. I can still see on the display only if I have a flashlight over it. What could be the reasons for my led backlight to go out? I know this is a unpopular computer but any help is appreciated.
Corrosion on motherboard (facing the keyboard)
After cleaning
Closeup of r005 (any significance to this?)
40 Pin connector
Full motherboard (facing the keyboard)
Full motherboard (facing away from keyboard)
Imgur link of the above pictures if you prefer imgur: http://imgur.com/a/hul8V
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
I had a similar issue but corrosion affected the inductor (PL7) on the top side. I tried to replace it, i'm thinking I overheated something else like the TI backlight controller :(
Punteggio 0
1 Commento:
I couldn't find any diagrams of the Pixel motherboard online, which makes it basically impossible to fix, so I just ended up buying a new one on eBay.
da
the fuse is the white one with a K on it. I bet it is shorted. Just replace it. I know almost a year later. But maybe for others.
Punteggio 0
1 Commento:
hi, by "shorted" you mean that it's blown, so i can measure infinite resistance beetwen its ends, or that it has zero resistance measured? my backlight is broken too...
da
Aggiungi la tua risposta
Tyree Gorges sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 875
