Salta al contenuto principale
Model A1288 / 8, 16, or 32 GB capacity
451 Domande Visualizza tutte
Domanda Chiusa
Broken Home button Spring?
I have broken off the gold looking spring on the logic board, i bourght a solderer to put it back on and now I have lost the bit? where can I get this it is the gold spring part right next to the lcd connector? thanks
Questa è una buona domanda?
Punteggio 0
1 Commento
Help... The same thing happened to me!!
da
Aggiungi un commento
9 Risposte
Soluzione Prescelta
I believe the diagram for the home button is like this: http://imageshack.us/photo/my-images/215...
In that image when the digitizer is in place 1 and 2 are in contact with each other and 3 and 4 are in contact with each other. The button just completes the final connection.
A wire soldered between 3 and 4 would do the job if you lost your spring.
As for martinkreis:
The spring is soldered. (see my answer here: gold spring for Homebutton connection )
Punteggio 1
1 Commento:
Hi,
do you know how this spring is fixed on the logic board?
Is it fixed with a screw or solded?
Which material should I use if I fix it self made?
da
Punteggio 0
Same here. I've read other forums where people have soldered a hair-thin wire to bridge the connection between the gold spring and the gold home button. All you need to do is bridge the connection. It is not the sensor that determines when the home button is being pressed, just the connector. That's what I understand.
Punteggio 0
1 Commento:
da
Hi,
Punteggio 0
my clip has broken off the number 4 in your diagram , can i get a new clip ?
Punteggio 0
where can i get a #2 Spring??
Punteggio 0
Could i just use foil?
Punteggio 0
2 Commenti:
for replace clip
da
It probably will work but not for long. You need something with a bit of "spring" to it so it keeps constant contact with home button.
da
for replace clip
Punteggio 0
do you know whats it called and where i can buy it
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 4,954
