Salta al contenuto principale
An Android 4.4 smartphone released in August 2014.
108 Domande Visualizza tutte
Phone Wouldn't turn on please HELP
So , my phone just cut out the other day , it wouldn't charge or turn on . When I try to do the Hard Reset it comes up but when I press the volume down or up . It blanks out in my face all of the time . If you can help me please do ..What do I need ? a new battery ??
Questa è una buona domanda?
Punteggio 12
1 Commento
what do you mean cut out?
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
I found that happen because i plugged my phone into my laptop. I was told to replug it, turn on the phone, correctly unplug the phone and then do a battery pull and full charge. If this does not work and your phone is less than a year old contact blu
Punteggio 1
1 Commento:
I have being using blu studio 5.0c phone for a while now , suddenly it turned off by itself this morning with the battery fully charged. I tried turning it on, it's won't turn on or charge either. Can you please help me out ?
da
May be this answer help you too, before do the following steps make sure your battery is in good condition or proceed while phone connected to charger
Punteggio 0
Aggiungi la tua risposta
Ronecha Forde sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,465
