Salta al contenuto principale
Modello A 1297 / Processore Intel Core 2 Duo da 2,66, 2,8, 2,93 o 3,06 GHz
1004 Domande Visualizza tutte
Domanda Chiusa
Backlight Fuse Location on Logic Board 661-5203 of MBP 17" (A1297)
I've been looking for 2 days now... Please help ! ~~~
Trouble finding a location of backlight fuse on... (details below)
Apple Logic Board: 661-5203
MacBook Pro 17" Unibody: Mid 2009, Model: A1297, 820-2610
Serial Number: W******V8YA
Thank you so much for the support !
Update (10/02/2015)
Which is the correct component for F9800 fuse in... (details are below)
Device: MacBook Pro 17" Unibody Mid 2009
Is it 2Amp 32V"' SMD 0402''' Package
or the 3Amp 32V SMD 0603 Package?
Because these pages got me little confused with F9800 & F9700 on the logic board.
But by the fuse dimensions, you are absolutely correct which is 3Amp 32VDC SMD 0603 package.
Questa è una buona domanda?
Punteggio 0
3 Commenti
Should not confuse you. All the links you posted are for different logic boards and different models . Yours is definitely F9800 3A 32V 603 package.
da
I guess F9800 & F9700 on the logic board... it seems not to identify the constant or indicated components !
da
That is correct.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Kenneth, here is the location of the fuse. It is a 3Amp 32V in a 603 package. Please remember that this is only to identify the fuse. If the fuse is blown, you will definitely have to check on the reasons why it blew. It's a pretty big fuse and it takes quite a bit to blow it. So check your LCD connector and other components for a short circuit.
Punteggio 1
1 Commento:
Thank you so much for the clear and lucid explanation !!!
This backlight of the LCD monitor has been on and off for last 2 month.
so, I was using my MBP with an external monitor, but in some cases... it becomes a primary monitor...
however... eventually last week, backlight went out!
so, for me... it is an abstruse to conjecture that which component caused the short circuit.
reluctantly, at this point... I would like to put one more chance to my MBP.
Thank you once again for your time and support !
Have a happy wonderful day~~~*
da
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,770
