Salta al contenuto principale
Also known as EOS 600D and released in March 2011, this camera can be identified by its SKU (SKU:5169BO32). This camera is a Canon Digital SLR with 18 megapixels.
52 Domande Visualizza tutte
Domanda Chiusa
Flash lens burned out, how do I fix it?
The built in flash rises up but the light does not turn on.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
If the camera battery is dying or faulty, it can cause problems with your flash. Remove your camera battery and charge it fully. If the problem persists, you might need to replace your battery. If your flash is burned out, you will need to replace it. Check out this troubleshooting page for more information.
Punteggio 0
Refer to the repair guide on how to replace the flash.
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 109
