Salta al contenuto principale
A sturdy tablet designed by HP for business and government use.
12 Domande Visualizza tutte
Can I increase hard drive capacity?
Can I increase the storage capacity of the hard drive? The initial capacity seems too small for what I need and would like to increase it.
Questa è una buona domanda?
Punteggio 1
1 Commento
The eidt bade work when concted to charching divice but not work when remove from it
da
Aggiungi un commento
6 Risposte
Risposta Più Utile
The ElitePad comes with 2Gb of RAM and Hard drive sizes vary from 32/64 Gb. If more space is needed it is compatible to external hard drives that can be connected to USB ports on the docking stations or the detachable keyboard.
Punteggio 1
You could use apps like Google Drive and Drop Box to store and access your information on a cloud system. You "expand" your memory storage and are able to access that info on other devices!
Punteggio 1
I have a 128 GB microSD card in my Elitepad 900 G1, it seems to work OK
Russ
Punteggio 1
The Elitepad has a microsd slot hidden under the cover symmetrical to the volume buttons. put a large microsd in there and you are away
Punteggio 0
No its built into the motherboard and you have a SD card slot that can go up to 64gb that's it.
Punteggio 0
Actually I used 128 MG cards n problem and reliably filled them up.
Punteggio 0
Aggiungi la tua risposta
Kyle Marques sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 20
Tutti i Tempi: 3,633
