Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3530 Domande Visualizza tutte
Replaced new screen and home button
I have changed my 5s screen with an new one that has all the extras. Camera, home button, ear speaker. Now the home button doesn't work.! I have heard the original home button is unique to the phone hardware and alough you probably can get the button to work it won't do fingerprint recognition. How do I get the new button to work without the fingerprint recognition?
Cheers
Old grumpy man
Questa è una buona domanda?
Punteggio 0
1 Commento
thanks again already ..
the answer ...No the parts are not directly interchangeable. Not because of the size. But due to the home button and display cable connectors are not compatible.
i was going to swop all the insides and screen to a 5s body. so all parts into 5s body. is that a possibility. ?
cheers
da
Aggiungi un commento
4 Risposte
Soluzione Prescelta
As per your i5S. You should use your old home button. Your Touch ID is directly related to that specific button part
Punteggio 2
Risposta Più Utile
Is the old button salvageable at all ? Your best bet is to just use the old one. Also make sure that the cable is properly connected and that the home button is properly mounted to the LCD assembly.
Punteggio 2
Hi thanks for your help. As the front facing camera that came with the fully fitted screen and home button etc doesn't seem to work i will be sending it back anyway.
I do have another question about an i phone 5.
Is it possible to fit all the parts and screen from an i phone 5 into a 5s body ?
I am quite good at the assembly so its just the chassis fittings that i don't know if they are the same ??
thanks again.
StUPid.
Punteggio 0
the answer ...No the parts are not directly interchangeable. Not because of the size. But due to the home button and display cable connectors are not compatible. i was going to swop all the insides and screen to a 5s body.
so all parts into 5s body. is that a possibility. ? cheers
NutZ
Punteggio 0
Aggiungi la tua risposta
Dumb Englishman sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 129
