Salta al contenuto principale
The LG G4 was released in the US in early June 2015, as always focusing on high-end specifications and a refined fashion sense that makes it stand out in the premium smartphone market. Each version of the phone will have a different model number based on if it is sold by a carrier or unlocked (US or International). Some LG G4's are known to have bootloop problems.
Front Glass lifted from frame
I have a T-Mobile LG G4 and I have noticed that the front glass panel is lifted up on the right edge of the glass...I can push it down but it lifts back up by itself no matter how much force I put on it. I was wondering if there was a way to fix this issue due to the fact that I really like this phone and would plan to keep it for a long while. Thank You in advance
Questa è una buona domanda?
Punteggio 1
1 Commento
Only screen replacement will work in this case.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
How long have you owned this phone? If it is a short time, you can send it back to the retailer for a replacement. If you have used it for a long time, then did you ever drop it and try to fix it by yourself? If yes, the adhesive gluing the screen and the frame may not be so strong enough to stick on the right way. And just like Candido said, you have to remove the disaply again and replace with the good quality adhesive. Here is how to replace LG G4 screen: https://www.youtube.com/watch?v=ZRgQ2rI9...
Punteggio 1
I usually see this happen when the phone screen has been replaced or removed and the adhesive that goes on the edges didn't stick or was not placed at all. . if that has not been the case and this happened with no damage to the phone then you are covered under the manufacture warranty. To fix this issue would require to remove the display from the frame to replace/add adhesive.
Punteggio 0
Aggiungi la tua risposta
noelngrn16 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,840
