Salta al contenuto principale
Android tablet by Acer, with a 10.1" screen, 1 GHz dual-core NVIDIA processor and a 16 GB hard drive. Released in 2011 with Android 3.0 Honeycomb.
Why is my tablet frozen on the Acer screen?
So a few days ago, out of nowhere, my tablet shut off and is frozen on the Acer screen. I already tried the reset and factory reset but it refuses to get off that screen!!! Pliss halp!!!
Questa è una buona domanda?
Punteggio 10
1 Commento
i didn't no my password again
da
Aggiungi un commento
4 Risposte
Soluzione Prescelta
Hold down on the power button and the volume down buttons for a 10 sec then do it again for another few seconds. Hope this helps
Punteggio 2
2 Commenti:
I tried these combinations and this did not work. I got a green android character displayed on the screen with a rotating symbol on its front side. After this completed, the green android character ended up in its back with a exclamation point above him. I'm assuming this is not a good thing. I thought maybe replacing the board containing the ram may be the next thing. I did not see any guides for this here. Has anyone tried this? I'm assuming it's the main board. I appreciate any info.
da
I feel that jumping from a default reset straight into swapping out the motherboard may be a bit more drastic than most people would like. There seems like there should be other options available at least. I'm currently researching this anomaly for a different tablet, the Pro12, which is having similar issues.
da
Hi I have a similar problem my Acer goes past the Acer screen to where the android word pops and it changes from blue to white , back and forth. Then the Android word disappears and within about a minute it comes back, about 3 minutes later it disappears again and just continues to do this. I have tried to reset it with no luck. Does anyone have any suggestions?
Punteggio 2
1 Commento:
@mjhickey61, were you ever able to get your tablet back to working functionally again?
da
i have the same problem and you didn’t have a reasonable answer what to do with it if the reset didn’t work ??????
Punteggio 0
1 Commento:
So, apparently there is no one with any give a %#*@ that wants to help us. Sorry y'all.
da
hi
looks like your moviNAND (eMMC) died.
Punteggio 0
Aggiungi la tua risposta
Erik Rivera sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 26
Tutti i Tempi: 5,369
