Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
no sound only during calls
the iPhone 5 has taken some heavy damage but it's still working fine, but when i make a call there is no sound. i can't hear the other side and the other side can't hear me, not even a dialling tone. i checked the earpice and the microphone with the voice memos app and it works fine, there is also good reception and i can surf the web and use other apps like Skype and whatsapp.
i did a little digging on the internet and some say the problem is the baseband chip U501_RF, is that true and if so how can IFIXIT?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Hi nicolasphilippides
I figured it out. you will need to reflow the baseband chip. take the logic board out and with a hot air rework station heat the baseband chip. i used 350 degrees celsius with air pressure on 5 with a hakko station and 4.4 mm nozzle, heat the chip in a circular fashion for 30 seconds.
if that doesn't do the trick or if the problem reoccurs you will need to replace 3 chips as they are all paired:
1. Hynix H2JTDG2MBR (nand flash)
2. Qualcomm MDM9615 (baseband chip)
3. U601_RF (baseband memory)
which is not that simple so basically not really worth it on an iPhone 5 IMO. thats all the information you need, good luck.
Punteggio 1
1 Commento:
Thank you very much :)
I don't have a hot air rework station but I will try by putting the baseband under a lamp for some minutes as I did for the greyed wifi problem on a 4S.
Hope it will work :)
da
Risposta Più Utile
Can you use the microphone and record things or did not work the game .Does music player through the speakers without a helmet. If all this work it may just be the Mic antenna. Here is a solution for it. hope this helps
https://www.youtube.com/watch?v=0jhWxYTV...
Punteggio 1
1 Commento:
thanks Jimfixer
speakers and mic are working fine. recording, apps, music through the mic and everything but no sound on calls.
unlike the video the iPhone 5 chips are covered with metal casing, pressing on it doesn't work. should i unsolder the metal casing and try to reflow the baseband chip?
da
I have exactly the same problem...
If someone can help us :)
Punteggio 0
Aggiungi la tua risposta
Nadav sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 398
