Salta al contenuto principale
Released September 2013 / Black, Blue, White or Pink Casing / 4GB of memory.
forgotten password, how do I factory reset?
My daughter put a password on her Chromo, Inc. 7" tablet (without permission) and has forgotten the password. Is there anyway to reset it? I cannot get customer service to answer this and they have no number to call. It also is not in the tiny "booklet" they call a user manual.
Thank you.
Questa è una buona domanda?
Punteggio 27
1 Commento
I have a Turbo - X Tablet (wintab 8inch) it is in Russian language, I want to set it to English how can I do this? Also I do not have the password?
da
Aggiungi un commento
20 Risposte
Risposta Più Utile
OK some people didn't explained it so well so here it is again for everyone's satisfaction and understanding.
PLEASE READ CAREFULLY, I GUARANTEE YOU IT WILL WORK. I HAVE DONE IT ON MORE THAN 5 DIFFERENT MODELS AND MANUFACTURERS.
1. Turn the tablet off by either using the power off option if the tablet turns on or Pressing and holding down the Vol. UP key and the Power Button until the screen goes black.
*once powered off please use the following method.
2. Press and hold both volume buttons, while holding Vol. UP & Vol. DOWN you will press and hold the power button for exactly 1 second (count on your head or say it out loud -Mississippi one-) and release the power button BUT KEEP HOLDING THE VOLUME KEYS DOWN.
3. You will hold down the Volume keys until you see the screen turn on and the logo show up. (WHEN YOU SEE YOUR TABLET LOGO INMEDIATELY RELEASE THE VOLUME BUTTONS)
*The problem in 90% of the cases I see daily it's a combination of bad timing and not following the proper steps because important details are assumed a day not explained.
Summary: So we turned of the device then hold both volume buttons and while holding them you will press and hold de power button for EXACTLY 1 second (Mississippi one){keep holding the volume keys} . You will release the volumen keys ONLY WHEN YOU SEE YOUR TABLET LOGO.
At which point it will take from 1 to 5 minutes depending on the tablet specs to show you the Android Recovery options, where you will use the Volume up and down key to circle between options and the power button as the "enter" for selecting whichever option is highlighted.
Hope this helps, I understand frustration, I see that everyday in my shop
Punteggio 14
8 Commenti:
Thank you so much!!!! This was very, very helpful!!
da
If the os is missing part of the BOOT files. How do I reinstall the os files... I have it connected to my Laptop but nothing showing up on laptop..
da
I have a Pro 12 android 6 "brick". I did reset it a number of times. It is still password protected in "Settings". Did RCA put in a second security "hurdle" in it's later models- ie. the Pro 12- Android 6? That would mean firmware or nothing.
da
Muchas gracias amigo, deberías hacer el tutorial en youtube ya que lo estuve buscando en idioma ingles y en español y no lo consegui.
da
I have a unisurf tablet. It has no up n down volume. Only reset. Also tf card holder which i do not have
da
Mostra altri 3 commenti
Hi I had the exact problem on the chromo android tablet, 1st thing you need to do is power off the tablet. Then press and hold both volume up and volume down key, while holding, press n hold power button for a sec to turn it on, continue holding both power keys, once powered on the screen will go blank but it will be illuminated with a black screen, release volume keys and punch volume up or down key to access recovery menu navigate menu with vol keys use power to select the options
Punteggio 4
5 Commenti:
Im sorry where i say "continue holdind both power buttons" I meant to say "continue holding VOLUME KEYS"
da
this brought me to the recovery menu, it suposedly wiped user data/factory reset, and its rebooting but its taking a long time to load
da
IT WORKED thank you very much for the answer
da
It's Not Working
da
I Tried It It's Not Working It Just Keep Going Back to the screen that says too many patterns attempts.
da
Hello,
Solution #1 if you hold the volume up and power button in at the same time while the tablet is shut off should get you where you need to be.
Solution #2
Found this info on another site, hope this helps. This user was having similar issue with reset.
1 Fortunately USB debugging had been set as default on the tablet.
2 I downloaded the SDK package with tools and platform tools.
3 That package had the adb programs that we needed to reset.
4 Unfortunately the adb couldn’t recognize the tablet.
5 The Android showed in Device Manager with a yellow triangle.
6 Updating the device driver on via web was useless.
7 I needed an updated USB driver
8 I found the updated USB driver for this device in Uberizer from TechKnow.
9 The driver that I needed was stored in C:\Program Files\Techknow\Uberizer\Usb driver\A1x livesuite 107 32 bit.
10 One computer used the 32 bit and one used the 64 bit. (both are available)
11 Finally I was able to access the SDK\platform-tools\adb.exe (program)
12 There area lot of tutorials on how to use SDK and adb but my mani problem was the adb recognizing my android device. If it doesn’t see the tablet you surely need the correct USB driver.
13 First I used Uberizer to connect.
14 Then I used the CMD prompt in windows and followed the path to where the adb program was stored. Mine was C:\Developer\SDK\Platform-tools\ (it came packaged within a package alt-bundle-windows-x86, but I moved the SDK portion to an easier place to access.
15 Dos commands opened the C:\Developer\SDK\Platform-tools16 I used “C:\Developer\SDK\Platform-tools\adb devices” to make sure the tablet was recognized.
17 Then I used the C:\Developer\SDK\Platform-tools\adb shell <return>
18 rm /data/system/gesture.key (note the space following “rm”)
19 Then I booted the tablet and the pattern lock was gone.
Punteggio 2
1 Commento:
I've done that, It didn't work. Neither did using the volume down button instead. This tablet seems not to fit any normal Android based options.
da
I forgot my password on my chromo android 4.1 how do I reset it
Punteggio 2
How can I reset I forgot password
Punteggio 2
I have a Chromo Android 4gb Tablet I can get in I forgotten my password how can I get in it
Punteggio 2
2 Commenti:
I have a Chromo Android 4gb Tablet I can get in I forgotten my passworld How can i get in please help me to get to my password thankyou
da
I have a Polaroid tablet that was given to me by a friend but his daughter put a password on it and I don't know how to override it or factory reset it. Can anyone help?
da
Need help on chromo tablet model:C12419
E-4GB
How to unlock screen password
Punteggio 1
I forgot my password chromoinc 4gb
Punteggio 1
i forgot my password on my chromo tablet
Punteggio 1
Ok first turn off the tablet push and hold on button at the same time pushing vol down then you should see android laying down push vol up then move using vol button to chose Factory reset then push power button then reboot restart good or chose clear password user data or I'd know. You have to reset whole tablet or deal withit
Punteggio 0
1 Commento:
Ummm..... I tried what you said and it didn't work I did what ya said and rebooted it and I still cant get in my tablet because of the password :(
da
I have a Turbo - X Tablet (wintab 8inch) and have forgotten password, how can I put it back to factory setting?
Punteggio 0
how to get in to my facebook
Punteggio 0
I did not think this could be done because the volume up and down button are one that you either depress one side for up or the other side for down, but it did. Here goes: Depress both the up and down side of the volume button and then press the Power on button for literally 1 second and then let go. DO NOT let up on the Volume Up and Down sides until you see the screen come on. When it does you can use the volume up or down to move cursor to choose the option to reset. Choose whichever option you want and select it by pushing the Power button. It worked and I will say that the screen came on just about ten seconds once I pressed the Power button for exactly one second. I really didn't think it was going to work. But it really did! Good Luck.
Punteggio 0
I got a lock on my granddauther tablet n forgot it
Punteggio 0
pass word is not working kindly help
i was using this dangol and now i got it rechrged
but it is not working why ?
plz can u rectify or suggest me
how to rec over the dangol
huawei-c398
ceo 197 #
Punteggio 0
1 Commento:
i WANT SOMW HELP TO RESTORE MY DANGAOL
da
I have a Chromo tablet,,,I don't remember Tha password so how can I get in...
Punteggio 0
It keeps asking me for an e-mail associated with this tablet, how do I bypass this ?
Punteggio 0
Reset your Acer Chrome tablet
  1. Click the Status area in the lower-right corner of the screen and click the Settings icon.
  2. Use the down arrow to scroll to the bottom of the page and select Advanced.
  3. Use the down arrow to scroll to the "Reset Settings" section and select Powerwash.
  4. Select RESTART.
Hope these steps help you!
Regards,
Lewis
Punteggio 0
I have a ematic tablet and i forgot tbe password pin ..how can i factory reset it ?? It dont let me go no where it just shows pin patterm
Punteggio 0
Turn tablet off, now press both up and dn. vol. buttons firmly and keep holding both at the same time.
Now press on/off button for 1 sec. no more. remain hold on vol buttons until Cromo appears then release. Give it a few seconds then press vol. up quickly. That should bring you to a menu.
Scroll down using vol. keys and enter with on/off. Reset and reboot, sounds simple does’nt.
It took me a couple or three tries.
Make sure you have a good charge on the tablet. One for yourself might not hurt either.
Punteggio 0
Aggiungi la tua risposta
danbethcorwin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 18
Tutti i Tempi: 35,597
