Salta al contenuto principale
HP Pavilion dv4t 14.1-Inch Widescreen Laptop.
Why is my screen pixelated?
I had opened a video for a school assignment and after a while, the video went haywire and now my display looks pixelated. Can you help me figure out what's wrong? I don't want to lose my files but I am unable to see my options on the screen.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Sophia P, could be a bad LCD or a bad GPU. Attach an external monitor and see if that displays properly. If it does, you have a bad LCD. If it does not than you are having issues with your GPU which is part of your logic board. That of course will require some major repair, i.e. logic board replacement or replacement of the GPU itself if you can get a new GPU for a reball..
Punteggio 1
3 Commenti:
Well I plugged a monitor to display and it's still doing the same thing. I just don't understand how a video would do that
da
Sophia P, do not look at it as in the video having caused this directly. The video just pushes the GPU a bit harder to process, If it is already having issues it does not like the being pushed and subsequently fails.
da
Okay well thank you for your help, much appreciated
da
Aggiungi la tua risposta
Sophia P sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 749
