Salta al contenuto principale
2.4 GHz Intel Core i3 with 4 GB RAM and 1 TB hard drive, shipped with Windows 8.1 as standard
10 Domande Visualizza tutte
Toshiba Satellite C50-A-1CK wont boot fan spins no display
Remove and test:
Battery
RAM( replace with another RAM)
HDD
CMOS battery
nothing works.
also as a last resort tried and reflow the motherboard chipset but still the same results
any ideas?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
I had this did oven reflow 220 degrees C for 8 minutes
worked
but when i went to put windows on (to sell it)
I left it overnight finishing the install the next morning it was doing it again
motherboard seems to overheat
make sure you get it over 195 C when you reflow as that is the solder melt temp
take it out after 7 minutes
(be careful its delicate when solder is soft)
let it cool
my board was twisted after but fitted and worked ok
Punteggio 0
Had the same problem here ( just putting one back together now).
Likely a PCH issue, so basically a case of dumping the board and cutting your losses. This model is having a lot of this issue.
Warming the PCH up at 150~180 probably might give you another couple of days but it'll fail again soon enough.
It's NOT likely a ball problem, rather the issue is in the internal gold connects of the chip itself.
Punteggio 0
Aggiungi la tua risposta
nearxos sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,812
