Salta al contenuto principale
Tickle Me Elmo is a children's toy from Tyco-Preschool, based on the character Elmo from the children's television show Sesame Street. It was introduced in the United States in 1996.
18 Domande Visualizza tutte
Why Elmo stop Vibrating?
Elmo stop vibrating, can I replace the vibrating part?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
jeaddy4, yes you can, if you can find it. Check the weight in the vibration system and make sure that the gear is okay. Take a look on here
Punteggio 1
3 Commenti:
Yes! Your answer help me find and repair the problem. The small gear (about a quarter inch in size) that fits into the larger gear was broken. The small white gear that was attached to the motor. Thank you.
da
Good for the older Elmos. Is it the same for the later ones?
da
@jeaddy4 - Struggling to find the little gear. How did you find a replacement?
da
Aggiungi la tua risposta
jeaddy4 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 3,577
