Salta al contenuto principale
Just want to turn off the alarm?
I have a Armitron Watch (model 45/7039) that I bought last week from Walmart. It works just fine, no notable issues; but I lost the instruction manual. The watch has an alarm setting, and after the alarm goes off at the scheduled time (and is stopped), it keeps going off every few minutes, until the next morning. As you can imagine this is very frustrating. I've looked everywhere (even the Armitron website!) for a copy of the instruction manual and it's as if the watch doesn't even exist! I just want to shut the alarm off for good. I also need instruction on how to get the watch out of military time. Any help?
Questa è una buona domanda?
Punteggio 15
8 Commenti
I wanted one thing. The main screen is the correct screen and not the alarm screen to turn off the alarm. I tried the reset button and the stop button. I found it only works on the main screen or the time screen.
da
How do you get to the stop watch timer part I lost my instructions and I can remember how to do it please help
da
Is am the up or down setting your timer
da
Who can pick out for me the best product from the list provided in this site? https://buylatestwatch.com/best-survival...
da
how do I shut the hourly alarm off on an FMDAW016 V398
da
Mostra altri 3 commenti
Aggiungi un commento
10 Risposte
Soluzione Prescelta
For my wife's Armitron it was press the RESET button and the ST/STOP button at the same time to turn the alarm function off
Punteggio 46
22 Commenti:
Oh my god,thank you I lost a lot time searching in a internet how take the alarm off ,and your advice help me ,thank you very mu ch
da
You are a lifesaver.... a god, actually THANK YOU!!!!
da
actually agree with the life saver! omg this thing was about to go out the window!
da
how do you turn on the alarm for a Kodiak watch
da
I have another brand watch and this worked! Thanks
da
Mostra altri 17 commenti
For my armitron, you have to press MODE until the alarm screen comes on, and then press ST/STP until the alarm signal goes away. To turn off 24h time, you press RESET from the main time screen.
Punteggio 13
2 Commenti:
thank you that was !#^&^$^ me off
da
My armitron pro sport is model 40/8309 it is water resistant to 330 ft. Duel time 1/1005 Chrono does not turn off the alarm with anything that I have tried on this page. I have turned it off before and it was simple but cannot find the u tube video I watched to do it anywhere. ANY IDEAS ON HOW TO TURN THIS UNNEEDED ALARM OFF!!!! PLEASE!!! IT GOES OFF AT 12AM EVERY NIGHT AND HAS TO BE STOPPED!!! HELP ME!!!
da
The Armitron digital watch I have only turns the alarm off on the main screen or the screen you see the time. Pushing the reset and ST/SP button turns the alarm off and on. I was not able to turn the alarm off on the alarm screen.
Punteggio 8
3 Commenti:
I hit all the buttons until that bell disappeared. In time mode held St/spt down while hitting the reset button a short press. Hold longer and it just spins through time. I should note that I am an adult, and any 6-year-old would have this problem licked in two minutes, then wonders why in the world anyone would ear a watch....
da
thank you, this really helped
da
My armitron watch had 5 alarms!!! I had to go in and deactivate each one that I didnt even know was set before it would stop going off at midnight. It's in the AL section. You'll notice alarm numbers where seconds would be. I hope this helps.
da
I have an Armitron (Model: AMDY6003) from Academy Sports. The way I turned off the alarm:
1. From the main screen (displays time), press and hold the lap/reset button (bottom right).
2. While the lap/reset button is still pressed, press and release the start/stop button (top right).
3. The little graph/icon showing the alarm is set will now disappear.
It worked for me. I hope it works for you too. I don't have the user's manual so just tried hitting buttons.
Punteggio 7
7 Commenti:
After looking for a fix to turn off the alarm, this was the only one that was well explained and worked!!!
da
Do you have a fix to switch from 24 hours to 12-hour display?
da
You sir are a hero I had to make a profile on this thing just to thank you
da
Thank you!!! Especially for describing the buttons!!
da
Thanks so much. It was gradually becoming frustrating but finally can rest my ears.
da
Mostra altri 2 commenti
Press and hold button 1&3 on the watch, it works for most of those cheap $8 - $10 watches from Walmart.
Punteggio 4
2 Commenti:
Mere mobile sonata Wr100m hai ,is me abhi cont. Alarm bajraha hai ,how to stop it kindly help, day n tm b show nehin karrahahe
da
Ivim2014@ gmail.com
da
On mine, I went to the screen where it shows what time my alarm goes off. I pressed st/stp and the alarm icon at the bottom dissapeared.
Punteggio 1
My sister's watch kept doing the same thing and it wouldn't stop .it was really annoying as you may imagine
I said let me see your watch and I can fix it .smiling and hoping I could I (being in the car on the road )there it out the window and then the problem was solved. Before this I tried all the little tricks and stuff I have seen and on this website none of which worked.. No I don't here the haunting sound of the beep
Punteggio 1
If you can't figure out how to turn off the alarm, wear the watch to Walmart, and go to the Jewelry dept. Make sure you are standing near the clerk when the alarm goes off. Let them know that you don't know how to shut it off. After a few minutes of that, they will shut it off for you!
Punteggio 1
1 Commento:
LOL!! That is too funny!
da
You have to let the alarm go for a full minute.
Punteggio 0
to get out of army time go to the time change mode and hold down until in the second area says A or P and to turn off the alarm click reset and st/stp
Punteggio 0
Aggiungi la tua risposta
[deleted] sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 11
Ultimi 7 Giorni: 101
Ultimi 30 Giorni: 536
Tutti i Tempi: 259,917
