Salta al contenuto principale
How to change the graphic card
Everything that is white on the display turns blue, i think it must be the graphic card that is default but im not sure, does anyone know about similar problems ?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
did you check the color profile settings in the display preferences panel?
the graphics processor issues are normally not a false color - it's more like this:
Punteggio 1
1 Commento:
Yes i checked all, its very simpel i you imangine that everthing that should be wihte is all of a sudden blue, ony the pure white.
da
we have an imac that is showing nothing but green hues.. it is NOT the display settings... starts before the OS even comes up. I was thinking it was the graphics card as well. This something that is normally a monitor problem more?
Punteggio 0
Aggiungi la tua risposta
Emile sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 5,533
