Salta al contenuto principale
Lo Huawei P8 Lite (Modello: ALE-L21), annunciato nell'aprile del 2015, punta sulla bellezza nella semplicità. Le sue fotocamere professionali permettono di scattare foto naturali e nitide anche in ambienti poco luminosi. La modalità beauty abbellisce il viso del proprietario in ogni selfie.
20 Domande Visualizza tutte
My phone doesnt start
Some days ago i tryed to root my huawei p8 lite tge device was rooted sucessefuly then i tryed to update my phone but when i try to turn on it shows the huawei sign and stays there for ever what to do please help
Sorry for bad english
Questa è una buona domanda?
Punteggio 20
6 Commenti
Hi. My phones battery was flat, it switched off, showed a flashing red lightning sign and then went blank. It won't charge or boot up. It has a red flashing light. How do I get it to charge or switch on?
da
I dont have a wipe/factory reset option and idk why? Instead it says for me to download a new recovery package via wifi.... Idk how pls help.
da
i was trying to find where the battery was located and found out it was the board,i put it back in place with panic and tried to turn on, it only showed the sign and turned off and i tried to plug it in with a adapter and didnt show charging sign,please help
da
I can't switch on my Huawei p8 lite
da
I have a problem related to my mobile huawei p8 lite that its just stuck on 5% during installing update and my power button also not works
What to do plz help
da
Mostra 1 altro commento
Aggiungi un commento
5 Risposte
Risposta Più Utile
Your English as not bad at all.
It sounds like a boot loop. To fix: power the phone off. Press and hold volume down and the power keys at the same time. Once the recovery menu pops up, select wipe data/factory reset and then wipe cache partition. Use volume up and down to move, power to select. This will erase everything on the phone but it should fix it.
The other thing is that if you took a factory update while rooted, you may need to reflash the ROM you had and then do a wipe.
Your phone is not ruined, wrecked or bricked. Its just a software issue with the OTA. A wipe should fix it, otherwise reflash and you will be golden.
Punteggio 6
8 Commenti:
and how do i do to reflash it
da
My phone doesn't startup after i did that
da
i tried but my phone didn't show me the recovery menu just a blank screen and after 5 seconds it showed the huawei sign again
da
This does not work
da
me too same probleme
da
Mostra altri 3 commenti
(NEW Method ) Recovering from bootloop/soft-brick. (with Contributors) for Huawei
Download au_temp.cfg (https://www.dropbox.com/s/2nr9cafmfr5qgw...)
Download Stock Rom (compatible android firmware on manufactures website www.huaweidevice.com )
Take out your sdcard from your device, and with an sdcard card adapter, connect to your PC, please do the following on your computer.
(Optional) Format SD Card)
1. Extract Stock Rom to root of SDCard.
2. Rxtract and copy au_temp.cfg into dload folder.
3. Make sure you have au_temp.cfg and UPDATE.app in your 'dload' folder.
4. Disconnect adapter.
5. Make sure your phone is switched off (Just to be safe, take out battery)
6. Insert SDcard into device.
7. Turn on device.
8. Recovery will autostart update process.
Punteggio 4
8 Commenti:
Hat bei mir 100%ig geholfen, tolle Anleitung
da
THX man you are my hero
da
I just get Software install failed pls help
da
Still stuck in the loop :( pls help
da
Don't work to me
Pls Help!! I tryied to fastboot the images to the phone, and don't work. I tryied to go to Factory Recovery and doesn't work. I tryied to rescue the phone with ADB and doesn't work (ADB didn't recognize the phone...). I tryied to take out battery, I had clean all the phone, I had saw if the power button works well, and it works well.... Pls guys help me, I am out of ideas and patience! I am tired... I will give up.....
da
wipe data /factory reset and then wipe cache partition.Use volume up and down to move,power to select.
Punteggio 1
1 Commento:
Even whilst doing this, the recovery menu doesn't appear either
da
For me this was the only solution https://hi6210sft.blogspot.com/2016/05/u...
Punteggio 0
Format the Micro SD card (This operation is optional).
Step 2. Copy the Software: main package to a directory named dload.
HUAWEI ALE-L21SD Card Software Upgrade Guideline
2016-6-8 Huawei confidential, no
spreading without permission
Page 6, Total8
Step 3. Copy the entire dload folder (with UPDATE.APP in it) to the rootdirectory of the Micro SD card. Check the filelist is right.
Step 4. Make sure your handset is power off. Insert the Micro SD card into the handset.Press the VOLUME UPandVOLUME DOWN key, and then press the POWER key to power on the phone and enter the Software Upgrade Mode.
Step 5. When the progress bar stop, the phone will restart automatically.
Punteggio 0
2 Commenti:
ridarafi93 :How can I help you ?
da
Aggiungi la tua risposta
miguelrego2000 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 15
Tutti i Tempi: 54,559
