Salta al contenuto principale
The Nyx Noba version runs on Android 4.1.2 Jelly Bean , has a 1 GHz processor speed 512 MB ​​RAM, 4 GB internal memory for all our files and apps, others have a slot for microSD up to 32 GB, and includes a 4GB microSD card.
The flash of a Nyx Noba cellphone is always turned on.
Hello.
I have a cellphone Nyx model "noba" which his flash doesn't turn off. I mean the flash always is turned on, even when the cellphone is turned off. The only way to turn off the flash is removing the battery from the cellphone. Is this a problem related to hardware or software? And how it can be fixed?. I hope someone can help me. Thanks.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta più utile
Disassemble the phone and look for a possible corrosion and shorts. Most of the flash "always turn on" problem occurs when parts shorts with the other component.
Or it you may want to look at your apps (i.e. flashlight,dimmer,bulbon,etc.) it might be in the "turn on" mode operation stucked into it.
Punteggio 2
1 Commento:
Thanks. I'll try it.
da
Aggiungi la tua risposta
Gerardo Hernandez Molina sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 4
Ultimi 30 giorni: 11
Tutti i Tempi: 540
