Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Touch ID problems with original sensor
Hi guys, basically I smashed my iPhone 6 about a week ago I replaced the screen but in the process I tore the Touch ID extension flex that runs behind the LCD. I ordered a new flex cable from eBay and installed it. Home button now works flawlessly but Touch ID does not. Now when I try to setup a fingerprint it does not say failed or anything, it just acts as if it does not know that I'm touching the sensor. The reach ability function also does not work. I have reseated the cables at least 10 times and have also restore the phone in iTunes, but it still will not work. Please guys can anyone help ?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Try another long flex. As long as your original home button and the little flex is intact, this should be work. eBay parts are often defective.
Punteggio 1
3 Commenti:
Yeah I thought to try this, how comes if my long flex is defective when I restored it didn't throw an error 53 though ? Weird huh :D need to get this sorted asap though as Apple pay does not work :( also everything is intact I have look under a magnifying glass the the little Touch ID flex and j can't see anything wrong with it
da
Yes I would think it would throw error 53 with bad long flex. Any chance you damaged the button itself?
da
Don't think so, looked at it under a magnifying glass and it looks fine. No nicks or kinks. Just doesn't work
da
Aggiungi la tua risposta
Bradley Munro sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 161
