Salta al contenuto principale
The third generation of the Samsung Galaxy tablet with a 7-in. screen announced on June 24, 2013. Repair of this device requires screwdrivers and prying tools. The device is available in white or gold brown with 8, 16, or 32 GB of storage, and includes a microSD slot that can hold up to an additional 64 GB of memory.
Why does my tablet keep turning off by itself
My tablet keeps shutting down once the battery level falls below 95%, and once it is off it doesn't turn back on unless the battery is fully charged, and I have to try to turn it on several times before it works, when it is off , and I try to turn it on the boot up screen comes on for a while then it just comes off again, I really need help with this , could anyone advise me if this is a problem with the hardware or software of the tablet? And do you have any suggestions on a solution to it?. Your suggestions will be very much appreciated.
Questa è una buona domanda?
Punteggio 4
3 Commenti
when i was playing on my tablet it shut off and keeps turning on and off idk what to do can some one help me plz
da
=== get a new device or wait or plug it in idk im guseing i have the problem to but i cant take the back off of mine BC i have an iPad Samsung plz someone help me to ===
da
My Samsung tablet was turning off by itself several times until it warmed up than it was fine. I tried someone's suggestion turning off Auto Sceen Lock and for some unknown reason it worked. It no longer shuts down by itself.
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Samsung has issue with there battery connectors all you need to do when it acts up is disconnect the battery and wait a few minutes then reconnect it . Here's a video explaining how to do it . I would not use anything but plastic to open the case a plastic knife or guitar picks or a spurge if you have one available to you. Metal knives can do damage to soft plastic circuit boards and cases
https://www.youtube.com/watch?v=lIi__P86...
Hope this helps
Punteggio 5
me too it do this when i use a lot of ram
Do this:Go in settings tap application manager and go to execute and do force quit on apps u don't use
Punteggio 1
1 Commento:
I've not completly solved the problem but connecting to your charger and leaving it for a while will reboot the system ..... until next time. Mauri
da
Mine is doing it also...on my second one and same thing going on ..thing is we have 2 of them and the one from Walmart doesn't do it but the one from T-Mobile does...makes me say hmmmm
Punteggio 0
Aggiungi la tua risposta
nigelsoheartlesslewis sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 42
Tutti i Tempi: 18,492
