forgot my phone password
How can i open it without using dialling screen.
Questa è una buona domanda?
maricel besinan, try the last 4 digit of your phone number. If you can not remember the number than the only way I know off is to remove the SIM card from the phone (if you have one) and enter the number below. This will erase everything on the phone that is not saved to a memory card (if you have one) or the SIM card,
*2767*3855#
If that doesn’t work, try
*0206*3855#
Tnx but i can't use the dialing screen coz it wont open while the phone is dialing sos,is there some ways how to reboot it?without entering codes,like turning it on theres a botton to be pressed or something to push while turning in on
1. Open your Phone you will see SOS on the bottom right. 2. Open SOS then it will say Call SOS proceed to Yes. 3. SOS call will be processed then press the Lock hold key to UNLOCK the screen. 4. Proceed to the keypad and finally 5. Dial *2767*3855#. There are no magic button combination.
Depends on what you need accessing. You can plug into a computer that is already trusted and retrieve your photos. But if you are trying to access other phone features you are out of luck. Your best bet is backing up your iPhone on a trusted computer then do a clean restore and load up your backup.
bjornfenwick, it's not an iPhone;-)
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,443
