Salta al contenuto principale
Guide di riparazione, smontaggio e soluzione problemi per la prima generazione di Apple iPad con Wi-Fi, disponibile con 16, 32 o 64 GB di spazio di archiviazione. Rilasciato nell'aprile 2010. Identificato dal numero di modello A1219. Le riparazioni sono semplici e non richiedono calore.
unknown error occured 1671
cant open or close ipad
Questa è una buona domanda?
Punteggio 15
1 Commento
1. Update iTunes to the latest version to ensure that it is compatible with the version of IOS and the iDevice with which we are working.
2. Update the antivirus and run a full system scan for infections.
3. Install the latest version of the computer operating system.
4. Connect the iPhone or iPod Touch to a high-speed USB port (USB 2.0 or higher).
5. How to Solve an Unknown Error 1671 Occurred on iPad
da
Aggiungi un commento
6 Risposte
Risposta più utile
iphone itunes error 1671
Punteggio 2
non riesco ad usare i pad
Punteggio 1
2 Commenti:
my ipad was not restore and not updating
it's showing the only showing itunes simble
da
my ipad showing the an error occurred 1671
da
did this error occur during a update?
try
Resolve iOS update and restore errors in iTunes
Resolve issues with an over-the-air iOS update
Punteggio 0
6 Commenti:
no
flickered and went to iTunes logo with charging pix
da
wont turn on or off tried the iTunes restore
da
So you see the itunes logo on the ipad and when connected it and tried to restore it you got 1671?
Try to restore the ipad in DFU Mode:
Step 1: Turn off your iPod touch / iPhone completely and connect to PC / mac
Step 2: Hold down the Power button for 3 seconds
Step 3: Without releasing the power button, also hold the Home button for 10 seconds
Step 4: Without releasing the home button, release the power button and keep holding the Home button for 20 seconds.
da
Sometimes you need to update or restore your iOS device and for this purpose you use iTunes applications. To transfer, restore, update iOS devices you simply need to connect your device to computer using USB cable and while going through some of the above activities it shows iTunes error 1671. It generally happens due to incompatible version of the iTunes or iTunes components are corrupt or damaged USB cable.
http://www.iosdevicerecovery.info/blog/c...
da
Johnny Martini - Thank you. The following fixed the 1671 error for my iPad.
da
Mostra 1 altri commenti
none of these ideas work
Punteggio 0
I had the same issues and it ended up being iTunes was still downloading software for the update. I don't have a clue why it prompted me to continue the update when it was still downloading. Look in the upper right-hand side of iTunes for the square box which has the downloading indicator on it. Make sure it's still not downloading before reacting to the prompts. Once it was done, I was clear for takeoff! Hope this helps some of you.
Punteggio 0
John martini's workflow solved my problem: apple 0: ifixit: 1 yay
Punteggio 0
Aggiungi la tua risposta
casinorat1968 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 9
Ultimi 30 giorni: 26
Tutti i Tempi: 48,760
