Salta al contenuto principale
Fourth generation of iPad, released November 2, 2012, available in 16, 32, or 64 GB models. Model Number A1458
How to fix ipad 4 wifi digitizer problems
how to fix ipad 4 wifi digitiser problem i bought this part : iPad 4 Screen Digitizer Assembly
so how do i fix it do i have to do anything diffrent or should i just follow this guide Sostituzione pannello anteriore iPad 4 WiFi>?
Immagine Replace a scratched or cracked front panel glass digitizer screen compatible with iPad 4. Includes: Front Glass Digitizer Panel, Blank Home Button, Camera Bezel, and Installation Adhesive.
Prodotto
$39.99
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
I have done 3 of these, just follow the instructions; Pre-read instructions first. Make sure you understand them fully. Take your time, heat the warmer often and WEAR SAFETY GOGGLES: glass flies everywhere when it cracks.
Before removing any of the protective plastic coverings (inside and out) and the adhesive backing pre-test. As an Apple Tech - the white lines on the digitizer should not be visible when fully inserted into the connector.
Place the LCD in-place with screws, then gently place the digitizer on top of it. Turn it on and make sure all corners, center bottom, etc works properly. test cameras, microphone and speakers, and Wifi, buttons, volumes, etc.
Punteggio 0
Aggiungi la tua risposta
manazir hussain sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 170
