Salta al contenuto principale
My backlight won't turn on, how can I fix this?
I have a gen 5 iPod Nano. When I turn it on, my backlight will be on and after a few mintues it starts to flicker and turns off completly. I've tried restoring it and changing the brightness settings but nothing seems to work. Everything else is fine, its just the backlight thats stuffing up! how do I fix it?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
most likely the ccfl bulb (aka the backlight) dies and you have to replace the lcd!
how old is the nano?
if it's covered by the 1yr warranty, i woulkd go to apple and let them replace the nano.
if it's older, get a new lcd from ebay and replace the lcd on your own.
the bad part is, ifixit has no step-by-step guides for the nano 5g.
but since the 5g is similar to the 4g you can use the 4th generation display guide and look at the 5g teardownto see the differences between those models
Immagine iPod Nano 5th Generation
Guida
iPod Nano 5th Generation Teardown
Difficoltà:
Moderato
Immagine iPod Nano 4th Generation Display
Guida
iPod Nano 4th Generation Display Replacement
Difficoltà:
Difficile
30 minutes - 1 hour
Punteggio 1
Aggiungi la tua risposta
Candy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 3,091
