Salta al contenuto principale
How to repair or replace the rear derailleur
I found a 18 speed Roadmaster Neutron bicycle in much need of repair. The rear wheel & derailleur have been partially removed & are hanging loose by the side of the frame. I'd like to safely clean & reinstall correctly. Any advise would be appreciated.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The following guides show how to remove and replace the rear wheel of your bicycle:
And here are a couple guides to help you fix or replace the rear derailleur on your bicycle:
Though not your exact model, check out this device page for a Roadmaster bicycle that may be similar to yours. On that page you'll find links to more guides that might come in handy as you repair other components on your bike.
Hope this helps!
Immagine Specialized Expedition Rear Derailleur
Guida
Adjusting the Rear Derailleur
Difficoltà:
Moderato
30 - 45 minutes
Immagine Specialized Expedition Rear Wheel
Guida
Rear Wheel Replacement
Difficoltà:
Facile
2 - 5 minutes
Immagine Trek 4300 Bicycle Rear Wheel
Guida
Trek 4300 Bicycle Rear Wheel Replacement
Difficoltà:
Moderato
Immagine 2006 Iron Horse Warrior
Guida
How to adjust and maintain 2006 Iron Horse Warrior Rear Derailleur Cables
Difficoltà:
Molto facile
10 - 20 minutes
Punteggio 1
Aggiungi la tua risposta
robertwente sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 10
Tutti i Tempi: 616
