Salta al contenuto principale
Guide per la versione Wi-Fi dell'iPad Mini 2. Annunciato il 22 ottobre e introdotto il 12 novembre 2013. L'iPad mini 2, noto anche come iPad mini con Retina Display, ha tutti i pixel dell'iPad Air in un più piccolo fattore di forma da 7,9"
iPad is disabled. Connect to iTunes. What to do?
iPad is disabled. The screen reads"Connect to iTunes". What do I do.
Questa è una buona domanda?
Punteggio 5
Aggiungi un commento
4 Risposte
Risposta Più Utile
Force it to recovery mode by holding power and home together with the device connected to computer until you see apple logo. Continue holding home button until device shows the connect to iTunes logo. iTunes will prompt to erase and restore as new
Punteggio 2
I have done the above but all I get is "iTunes could not connect to the iPad because it is locked with a passcode. You must enter your passcode on the iPad before it can be used with iTunes". Please someone help me x
Punteggio 1
Your iPad has been synced with iTunes: directly connect the iPad to iTunes to restore it;
Your iPad has never been synced with iTunes: set your iPad into recovery mode and then connect to iTunes;
Suppose iTunes doesn’t detect the iPad, using iCloud service or a third-party program like Joyoshare UltFix.
Punteggio 1
It's a A1489 and the S/N is dmpo3ayufcm5 . If you are the owner, please contact me nehmo54@hot mail DOT com . 2222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222222
Punteggio 0
Aggiungi la tua risposta
Alonzopi sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,606
