touch screen does not respond
Why does my touch screen not respond every time I touch it?
Questa è una buona domanda?
mikecornerstone, could be a bad digitizer. Of course, you do want to try a soft reset first Soft Reset:
Hold the power switch for twenty seconds. You will need to slide the power switch along and hold it for twenty seconds before releasing it. ...
Your reboot screen should appear when you release the power switch.
Wait a minute or two to give your device time to reboot
Turn the Kindle back on.
After that you most likely will have to replace the digitizer. Here is the guide for it
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 21,005
5 Commenti
My screen has only 1 area where it doesn't responde
da Jane C
Mine similar issue just touchscreen buttons on bottom that make it so I can switch apps
da Heather Clements
Same issue. Amazon hopefully will send a replacement. Switch to Samsung.
da Andrew Beck
Help my kindle fire hd won't touch anymore and it's touch screen
da courtney day
My toch screen is frozen with a yellow line around
da omawol
