Salta al contenuto principale
The Panasonic Lumix DMC-TZ5 was released March, 2008. It is the third camera in the TZ series, with a 3.0 inch viewing screen, 28-280 lens (10x optical zoom) and 9.1 megapixels. The TZ5 also has 720p HD video recording.
22 Domande Visualizza tutte
lens error-message-please turn camera off and on again
When turning camera ON, all appears normal for a few seconds, then the ERROR MESSAGE "PLEASE TURN CAMERA OFF AND THEN TURN ON AGAIN".
When turning OFF, the lens stays out.
When turning back ON, the lens retracts, then extends and stays out, and the process repeats. (The shutter does not work during the few seconds that operation appears NORMAL.)
I've replaced the battery with a fully-charged one. No difference in operation.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
It sounds like the lens is jamming. You might have some physical damage, some debris in the gears or mechanism, or it's just worn out. You could try taking it apart and cleaning out the gunk. Good luck, but you will probably end up buying a new, better camera.
Punteggio 1
Aggiungi la tua risposta
jhkmtk44 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 20
Tutti i Tempi: 2,122
