Salta al contenuto principale
Quinta generazione dell'iPhone. La riparazione di questo dispositivo è semplice e richiede cacciaviti, strumenti di apertura e pazienza. Nero o bianco, GSM/CDMA / 16, 32, o 64 GB.
2193 Domande Visualizza tutte
Replacement Power button not pressing or clicking
Hi all,
My power button stopped clicking in - when you pressed against it the button never moved and didn't click.
I brought a new power button ribbon cable and replaced it.
When I put the button in and hold the bracket against it the button works and clicks, however as soon as I put 1 screw in the bracket the power button stops clicking and goes stiff again.
I have made sure the power button is in correctly, metal bracket down etc.
Ive tried 2 power ribbons now and they all click, just not when the bracket is screwed in.
What gives?
Thanks in advance
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Risposta Più Utile
try backing the screw that holds the bracket out 1/2 turn to a full turn. Sometimes if they get tightened all the way down it will not click
Punteggio 1
Try taking the back glass off, fold a small piece of paper and put it under the power button for a temporary fix.
Punteggio 0
Aggiungi la tua risposta
Andrew sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 68
