Keyboard Backlight only glows in center
NOTE: I am aware of this thread Keyboard backlight only glows in center but my problem is not caused by a spillage.
I've been repairing a macbook pro for the last couple months on and off.
I've learned a lot along the way and have realized some things I did wrong.
The keyboard was sticky so I replaced it, but ended up I guess damaging the kb backlight because it now does not work. It diffused evenly among the keys before.
I now bought a replacement keyboard backlight, and it diffuses brightly to the few center keys then very dimly among the others, and only shines through the letters of the few center keys and none of the others.
I've re-inserted the LEDs in the plastic film to make sure they are correct placed, and I still have the same problem.
I have a feeling that it is a problem with the backlight I purchased, which even though states is compatible with my model looks quite different than the original I have.
Should I buy another one from a different seller and retry?
Could it be a problem with the replacement keyboard?
Thanks everyone
Here is an imgur album with pictures of the problem on full brightness click to go to album
Questa è una buona domanda?
2 Commenti
Get the proper part number off the original keyboard. Don't spit into the wind or try to get an improper replacement part to function correctly.
da mayer
Thanks, yes it turned out to be a wrong replacement. I figured because the seller listed my model under compatible I should go with it, but the LED layout was different.
da Anthony
