Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Apple Logo and Blue/Red screen
As soon i see this issue a went to itunes to Restore the phone and I got an error 9.
But i pull of the screen to disconect and then put it back and it start doing the same. I press the Home+Start Button for 10 seconds and the phone start to run normaly fixed, but after like 20 minutes it start doing the same thing it went the Apple logo and the Blue/Ref screen once and once again.
I dont wanna thing that is a Logic Board Damage.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Has it been repaired before? Water damaged? Why don't you just warranty it?
Punteggio 0
1 Commento:
Never Repaired, Never fall in Water. Just a hard fall but in floor. The Warranty did not accepted because he had a hard hit in the back of the phone.
da
Risposta Più Utile
Try the front camera and changing it out with a new one.
Punteggio 1
1 Commento:
This is a good idea, but before breaking into the phone you should try a few different stock Apple cables, as well as making sure iTunes is up to date. Red and Blue screens are typically caused by Long screw damage, where the copper traces on the board get damaged enough to cause shorts. This rarely happens from a fall though.
da
Aggiungi la tua risposta
Papo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 460
