How do you change the torque converter
How does one change the torque converter on a cb400a Hondamatic motorcycle?
Questa è una buona domanda?
Wayne, it goes something like this:"
Drain all oil from the engine
Remove the torque converter case
Remove the torque converter by applying a screwdriver blade to the groove in its periphery
NOTE: Use care not to damage the gasket surface of the crankcase.
REmove the needle roller bearings. Check them for wear, damage or other defects.
@miltonhope Here is how to install the torque converter
Put the needle roller bearing on the stator shaft.
Install the torque converter in the following sequence:
Place the gasket on the crankcase, then press the two dowel pins into their respective positions.
Note:
Pour the specified amount of oil into the engine through the oil filter opening.
Let me know if this works for you. If not, I can probably get the complete manual for you.
how do you pu t it back on, mine wont go back on all the way
Im trying to figure this out as well
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 343
