Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3530 Domande Visualizza tutte
Domanda Chiusa
rear camera and flashlight not working front camera behaving oddly
Hello! After replacing a cracked LCD on my Iphone 5S everything worked perfectly. The front camera worked well right after the replacement. The rear camera aswell. Didn´t check the flash. Because im tired of fixing lcd´s I got the most massive case I could find (you even have to screw it secure with 6 pentalobe screws).
After assembling the case the rear camera wouldnt work at all (black screen, photo app crash), the flash wont work anymore (cant even turn on the flashlight, the symbol is unchecked whenever i release my finger from it, no light even when holding it down), and the front facing camera behaves oddly. It inverts all pictures.
I dont even know what caused this error. I doubt all 3 parts malfunctioning at the same time and dont know how to fix it. I hope you know how to help me!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
It is likely that the back camera connector came unplugged or damaged when you were changing the LCD. Time to take out all those pentalobes and check the connectors.
Punteggio 2
1 Commento:
first of all, thanks for your answer brian! the connector would explain the back camera (and maybe the flash too?), but why would the front facing camera behave so oddly?
da
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,781
